*internalsupports()
Creates an internalsupport in HMASCII format.
*internalsupports (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the internalsupport.
- name
- The name of the internalsupport.
- color
- The color of the internalsupport. Valid values are 1-64.
To create a internalsupport with ID 100, name "my-entity", and color 1:
*internalsupports(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022.2
