tables
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- cardimage
- The name of the assigned card image.
- cardimagetype
- The type of the assigned card image.
- cellvalue
- The value at a specific row and column. Valid for hm_getvalue query only.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- columndatatype
- The data type for a specific column. Valid for hm_getvalue query only.
- columndatatypename
- The data type name for a specific column. Valid for hm_getvalue query only.
- columndescription
- The description for a specific column. Valid for hm_getvalue query only.
- columnentitytype
- The entity type for a specific column if that column is of type entity. Valid for hm_getvalue query only.
- columnlabel
- The label for a specific column. Valid for hm_getvalue query only.
- columns
- The number of columns in the table.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- dtablevalue
- The constant value.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- rows
- The number of rows in the table.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022.2 - Added new data name dtablevalue.
