retractors
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- EL_ID
- The element ID initially connected to retractor.
- Elem_size
- The target element size for released elements.
- entityselection
- The ID of the bar element selection for inside belt webbing.
- Fct_ID1
- The function identifier defining loading force scale factor versus pullout when retractor is locked.
- Fct_ID2
- The function identifier defining unloading force scale factor versus pullout when retractor is locked.
- Fct_ID3
- The function identifier defining pretension as a function of time, force versus time, length versus time, or energy versus time.
- fedlength
- The fed length.
- filmspoolcurveid
- The ID of the film spool effect curve after locking.
- flagtodisableelements
- The flag to disable elements definition.
- Force
- The maximum retractor force for pretentioner locking.
- forcevalue
- The retractor pretension force value.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- lengthfractionpullin
- The length fraction for retractor element pull-in.
- lengthfractionpullout
- The length fraction for retractor element pull-out.
- loadingcurveid
- The ID of the loading curve.
- loadlimitcurveid
- The ID of the load limit curve for the load limiter stage.
- loadlimiter
- The number of load limiter stages.
- loadlimitflag
- The flag for reference length selection.
- loadingsensorid
- The ID of the sensor triggering the load limiter stage.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- Node_ID
- The anchorage node ID.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- pretensionercurveid
- The ID of the characteristic force limit curve for the pyrotechnical pretensioner.
- pull
- The amount of pull-out between time delay ending and retractor locking, a length value.
- Pullout
- The authorized amount of seatbelt release before locking.
- retractorcpoint
- The ID of the seatbelt control point.
- retractornodeid
- The ID of the retractor node or node set.
- retractorparent
- The ID of the parent seatbelt.
- seatbeltelemid
- The ID of the seatbelt element or element set, depending on retractornodeid.
- Sens_ID1
- The sensor identifier for retractor locking.
- Sens_ID2
- The sensor identifier used for pretension activation.
- sensorid1
- The ID of sensor 1 of type *ELEMENT_SEATBELT_SENSOR.
- sensorid2
- The ID of sensor 2 of type *ELEMENT_SEATBELT_SENSOR.
- sensorid3
- The ID of sensor 3 of type *ELEMENT_SEATBELT_SENSOR.
- sensorid4
- The ID of sensor 4 of type *ELEMENT_SEATBELT_SENSOR.
- signedsensors1
- A positive or negative signed value.
- signedsensors2
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- Tens_typ
- The type of pretensioner.
- timedelay
- The time delay after the sensor triggers.
- type
- The type of retractor. Available types are node (1) or set (10).
- unloadingcurveid
- The ID of the unloading curve.
- Xscale1
- The abscissa scaling factor for function fct_ID1 and fct_ID2.
- Xscale2
- The abscissa scaling factor for function fct_ID3.
- Yscale1
- The retractor force.
- Yscale2
- The ordinate scaling factor for function fct_ID3.
Version History
2017.1
2020 - Added new config value 401. Added new data names color_rgb, entityselection, filmspoolcurveid, flagtodisableelements, forcevalue, lengthfractionpullin, lengthfractionpullout, loadlimitcurveid, loadlimiter, loadlimitflag, loadsensorid, pretensionercurveid, retractorcpoint, retractorparent, signedsensors1 and signedsensors2.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022.2 - Added new data names EL_ID, Elem_size, Fct_ID1, Fct_ID2, Fct_ID3, Force, Node_ID, Pullout, Sens_ID1, Sens_ID2, Tens_typ, Xscale1, Xscale2, Yscale1, Yscale2. Added new config value 201.
