*solidmap_equivalence2
Equivalences two sets of nodes for solid mapped meshing.
*solidmap_equivalence2 mark_id tolerance find_faces
HyperMesh Tcl Modify Command
This command equivalences two sets of nodes, based on a given tolerance and, optionally, does a special find_faces operation.
For equivalencing, the first set of nodes are from the elements in the solidmap and ^faces components. The second set of nodes consists of all of the nodes not included in the first set but falling within the specified tolerance.
For the find_faces operation, 3D elements in the solidmap component are used to find the faces. All pre-existing faces are filtered out and the remaining faces are added to the ^faces component. See the command *solid_facesfind. This step is useful for continuing with the next solid map operation.
- mark_id
- The mark ID containing the elements. Valid values are 1 and 2.
- tolerance
- The value of tolerance used for finding nodes during the equivalencing operation.
- find_faces
- The flag indicating whether to perform the special faces operation.
To equivalence the elements in mark 2 with ^faces nodes using a tolerance of 0.1 and finding the new faces:
*createmark elements 2 displayed
*solidmap_equivalence2 elements 2 0.1 1
# Handle error
Version History
2022.2
