*smartrules()
Creates a smartrule in HMASCII format.
*smartrules (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the smartrule.
name
The name of the smartrule.
color
The color of the smartrule. Valid values are 1-64.
To create a smartrule with ID 100, name "my-entity", and color 1:
*smartrules(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022.2
