hm_getactiveplotcontrolminvalue
Returns the minimum value for the active plot control together with the entity ID.
hm_getactiveplotcontrolminvalue plot_type entity_type mark_id
HyperMesh Tcl Query Command
Returns the minimum value for the active plot control together with the entity ID. There can be only one active plot control for every plot type.
plot_type
The type of plot for which the result values are queried. Valid values are contour, vector, and tensor.
entity_type
The entity type for which the values are queried. The valid values are nodes, elements, and components.
mark_id
The ID of the mark containing the entities that are considered in the evaluation.
Examples
To get the minimum value of the active contour plot for displayed nodes and the corresponding node ID:
*createmark nodes 1 displayed
hm_getactiveplotcontrolminvalue contour nodes 1
   # Handle error
Version History
2022.2
