hwISession CaptureDesktop
Captures the entire desktop to an image file.
hwISession_handle CaptureDesktop type, filename, (quality)
Tcl
This command captures the entire desktop to an image file.
type
The file type that you want to save the captured image as. The file type options include: BMP, JPEG, TIFF, PNG or saved to the clipboard.
filename
The file name that you want to call the captured image.
(quality) (Optional)
The level of quality or compression that you want to make the image.
hwi GetSessionHandle sess;
sess CaptureDesktop png MyPicture.png;
Error
Returns success (0) or an error code.
Keywords
Tcl
Create
