hwISession GetXMLImageLinkMode
Indicates whether the image links in the exported PowerPoint file have embedded or linked images.
hwISession_handle GetXMLImageLinkMode
Tcl Query
This command indicates whether image links in the exported PowerPoint (XML or XML_2007) have embedded or linked images. True is returned if the exported PowerPoint file has embedded or linked images. If not, false is returned.
hwi GetSessionHandle sess;
sess GetXMLImageLinkMode;
Error
Returns success (0) or an error code.
Keywords
Tcl
Query
