hwISession CaptureWindow
Creates an image file of a window on the current page.
hwISession_handle CaptureWindow win_id, type, filename, dimension_type, width, height, quality
Tcl Modify
- win_id
- The ID of the window which needs to be captured.
- type
- The type of file. Options include: BMP, JPEG, TIFF, PNG, and Clipboard.
- filename
- The file name of the captured image.
- dimension_type
- Specifies the width and height units of the final image, which can be in percent or pixels.
- width
- The width of the captured image in percent/pixels.
- height
- The height of the captured image in percent/pixels.
- quality (Optional)
- The level of compression (default is 100). This is used only in JPEG type captures.
hwi GetSessionHandle sess
sess CaptureWindow 1 png Pic.png percent 150 150;
sess CaptureWindow 2 jpeg Pic.jpeg pixels 1280 960 90;
Error
Success (0) or an error code.
