hwISession SetXMLImageLinkMode
Sets whether the images in the exported PowerPoint file have embedded links.
hwISession_handle SetXMLImageLinkMode use_links
Tcl Modify
This command sets whether images in the exported PowerPoint file (XML or XML_2007) are embedded or linked images.
- use_links
- The input is true or false.
- true
- If you want the images in the exported PowerPoint file to be embedded or linked images.
- false
- If you do not want to have embedded or linked images.
hwi GetSessionHandle sess;
sess SetXMLImageLinkMode true;
Error
Returns success (0) or an error code.
Keywords
Tcl
Modify
