hwISession CaptureDesktopByArea
Captures a portion of the desktop to an image file.
hwISession_handle CaptureDesktopByArea type, filename, left, top, width, height, (quality)
Tcl
This command captures a portion of the desktop to an image file.
type
The file type that you want to save the captured image as. The different file types include: BMP, JPEG, TIFF, PNG, or saved to the clipboard.
filename
The file name that you want to give the captured image.
left
The left coordinate of the region to capture, in pixels.
top
The top coordinate of the region to capture, in pixels.
width
The width of the region to capture, in pixels.
height
The height of the region to capture, in pixels.
(quality) (Optional)
The level of quality or compression that you want to make the image.
hwi GetSessionHandle sess;
sess CaptureDesktopByArea png MyPic.png 25 24 1000 1000
Error
Returns success (0) or an error code.
