hwISession UnloadXMLFile
Unloads a previously loaded XML file, freeing the associated memory.
hwISession_handle UnloadXMLFile filename
Tcl Query
filename
The name of a previously loaded file.
Error
Success (0) or an error code.
Unloading the file will not invalidate references to it in the session.  Also, no effort is currently made to remove such references. Instead, if there are still existing references (such as in a plot note), the XML file will be automatically reloaded.
