hwISession GetHWCHandle
Returns the HWC Record and Playback interface object to load HWC files and execute HWC commands.
hwISession_handle GetHWCHandle hwcHandle
Tcl Query
This command retrieves a handle to load HWC files and execute HWC commands.
- hwcHandle
- The user-defined name of the HWC handle that you want to create with this command. In the examples below, the HWC handle is "hwcHandle".
hwi GetSessionHandle sessHandle
sessHandle GetHWCHandle hwcHandle
Returns: hwcHandleError
Returns the HWC handle name if successful.
Returns an error message if the command fails.
