hwISession GetDataFileHandle
Returns the data file interface object for a given file.
hwISession_handle GetDataFileHandle filehandle, datafile
Tcl Query
You need to load a data file (for example, test.dat) in the path specifed before you can get a handle with the above arguments.
- filehandle
- The user-defined name of the file handle that you want to create with this command. In the examples below, the file handle is "ABC".
- datafile
- This argument can be of two types:
set FileName "D:/temp/test.dat"
hwi GetSessionHandle sessHandle
sessHandle GetDataFileHandle ABC $FileName
Returns: ABC
sessHandle GetDataFileHandle ABC "D:/temp/test.dat"
Returns: ABC
Returns the file handle name if successful.
Returns an error message if the command fails.
