hwISession CaptureScreenByAreaPercentage
Captures the screen to an image file.
hwISession_handle CaptureScreenByAreaPercentage type, filename, left, top, right, bottom
Tcl
This command captures the screen to a file, requiring you to specify or resize the window region to be captured. This version takes percentages as parameters of the screen (expressed as decimals between 0 and 1) for the input.
type
The file type that you want to save the captured image as. The different file types include: BMP, JPEG, TIFF, PNG or saved to the clipboard.
filename
The file name that you want to give the captured movie.
left
The left side coordinate of the captured region in terms of screen percentage (a decimal between 0 and 1).
top
The top side coordinate of the captured region in terms of screen percentage (a decimal between 0 and 1).
right
The right side coordinate of the captured region in terms of screen percentage (a decimal between 0 and 1).
bottom
The bottom side coordinate of the captured region in terms of screen percentage (a decimal between 0 and 1).
hwi GetSessionHandle sess;
sess CaptureScreenByAreaPercentage png Pic.png .25 .25 .75 .75;
hwi GetSessionHandle sess1
sess1 CaptureScreenByAreaPercentage "clipboard" E:\Scratch\CaptureScreenAPI_Test .25 .25 .75 .75;
Error
Returns success (0) or an error code.
Keywords
Tcl
Create
