poIMeasure SetMagnitudeDef
Sets the measure magnitude definition.
poIMeasure_handle SetMagnitudeDef definition
HyperView Tcl Modify
This command sets the measure magnitude definition. Only valid for a distance type measure resolved in a rectangular system (including Relative Displacement, Distance Between, Incremental Distance, Minimum Distance). Measure magnitude definition includes:
X+Y+Z: xyz norm = sqrt(x^2+y^2+z^2)
X+Y: x-y norm = sqrt(x^2+y^2)
X+Z: x-z norm = sqrt(x^2+ z^2)
Y+Z: y-z norm = sqrt(y^2+z^2)
None: Do not show magnitude and define as X+Y+Z
definition
The measure definition. Options include: X+Y+Z, X+Y, X+Z, Y+Z, and None.
Returns 0 if successful, otherwise an error code.
