poIMeasure SetType
Sets the measure type.
poIMeasure_handle SetType
HyperView Tcl Modify
This command sets the measure type. Measure types include: Position, Relative Displacement, Distance Between, Incremental Distance, Minimum Distance, Relative Angle, Angle Between, Incremental Angle, Static MinMax Result, Dynamic MinMax Result, Nodal Contour, Elemental Contour, Component Contour, Node Path, and Yaw Pitch Roll.
Returns 0 if successful, otherwise an error code.
