poINote SetBackgroundColorMode
Sets the color mode for the background fill of the note.
poINote_handle SetBackgroundColorMode mode
HyperView Tcl Modify
This command sets the color mode for the background fill of the note.
- mode
- The color mode to be set. The following options are available:
- "User"
- Allows you to specify a user defined color using the poINote SetColor command.
- "Component"
- The color to which the entity is attached will be used (if available), otherwise the default color will be used.
- "Contour"
- The contour color of the entity to which the note is attached will be used. If no contour is available, gray will be used.
Returns 0 if successful, otherwise an error code.
