poINote SetPositionType
Sets the position type of the note.
poINote_handle SetPositionType type
HyperView Tcl Modify
This command sets the position type of the note.
type
The position type to be set. The following options are available:
"screen"
This option sets the note to use screen coordinates (X and Y location on the screen).
"coordinates"
This option sets the note to use 3D coordinates (X, Y, and Z in model coordinates).
Returns 0 if successful, otherwise an error code.
