poISCL GetUseIntersections
Gets the option used to use intersections of the path with elements as intermediate points.
poISCL_handle GetUseIntersections
HyperView Tcl Query
This command returns the option used to use intersections of the path with elements as intermediate points.
To get the option to use intersections of the path with elements as intermediate points:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl GetUseIntersections
hwi CloseStack
None.
