poISCL SetUseIntersections
Specifies whether to use intersections of the path with elements as intermediate points.
poISCL_handle SetUseIntersections option
HyperView Tcl Modify
This command sets the state whether to use intersections of the path with elements as intermediate points. The default value is Off.
option
Use intersections for the Path (true/false).
To set the option to use intersections for the Path:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl SetUseIntersections option
hwi CloseStack
None.
