poISystem GetOrientationByNodeMode
Gets the orientation mode for the coordinate system using three nodes.
system_handle GetOrientationByNodeMode
HyperView Tcl Query
This command returns the orientation mode for the coordinate system using three nodes. Mode can only be returned for a rectangular system. The return value can be “x-xy”, “x-xz”, “y-yx”, “y-yz”, “z-zx”, “z-zy”.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetUserDefinedSystemHandle sys1 “UserSystem 2”
set mode [sys1 GetOrientationByNodeMode]
hwi CloseStack
Returns an empty string if there is an error.
