poISystem GetOrigin
Gets the origin of the coordinate system.
system_handle GetOrigin
HyperView Tcl Query
This command returns the origin of the coordinate system. The origin can be obtained for model systems, as well as user-defined systems.
To get the origin of a coordinate system:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSystemHandle sys1 "System 1"
model_handle GetUserDefinedSystemHandle sys2 "UserSystem 2"
set origin1 [sys1 GetOrigin];
set origin2 [sys2 GetOrigin];
hwi CloseStack
None.
