poITensorCtrl GetDataComponent
Gets the current data component label.
poITensorCtrl_handle GetDataComponent
HyperView Tcl Query
This command returns the current data component label.
None.
Copies tensor data to the clipboard.
Gets the averaging state.
Gets the color for a given tensor component.
Gets the color mode for tensors.
Gets the flag to indicate if corner data is requested.
Gets the current plot style.
Gets the current tensor data type.
Gets the dimension state, either enabled or disabled.
Gets the tensor control display mode.
Gets the display mode list used for drawing the tensors.
Gets the pool state, either enabled or disabled.
Gets the auto load/unload tensor data state.
Gets the font name being used to draw the tensor plot text in the graphics area.
Gets a handle to the poITextAttribute interface for the tensor plot text.
Gets the type of head that is being drawn on each tensor.
Gets a list of valid head types that can be used when calling SetHeadType.
Gets the current layer label.
Gets the legend control object for tensor control.
Gets the multiplier for tensor results.
Gets a list of all the tensor plot styles stored in the tensor controller.
Gets the result system ID.
Gets the scale value used to display tensors.
Gets the scale mode used to display tensors.
Gets the size of the selection set.
Gets the scale factor for the shear component.
Gets the state of the "Show Midside Node Results" option for the tensor control.
Gets the state of the tensor's prefix draw mode.
Gets the state of the tensor's value draw mode.
Gets the tensor format.
Gets the tensor plot text color.
Gets the maximum threshold.
Gets the enable/disable state of the maximum threshold.
Gets the minimum threshold.
Gets the enable/disable state of the minimum threshold.
When nodal results are in use, multiple results may exist for nodes along part boundaries. In these cases, the returned list will contain the first nodal value encountered, while the nodal values for the other parts will be omitted.
Removes a plot style with the specified name.
Renames an existing/old plot style with a new name.
Resets the contour controller settings with a memorized plot style.
Captures the current tensor controller settings and saves it with the given name.
Sets the flag to indicate if results are element/node associated.
Sets the color for a given tensor component
Sets the color mode for tensors.
Sets the flag to indicate if corner data is requested.
Sets the current plot style.
Sets the data component for a given component label.
Sets the data type for the tensor control.
Sets the dimension state: enabled or disabled.
Sets the tensor control display mode.
Sets the dimension state, either enabled or disabled.
Sets the auto load/unload tensor data state.
Sets the font by name.
Sets the type of head that is drawn on each tensor.
Sets the current layer for the specified pool.
Sets the multiplier for tensor results.
Sets the result system ID.
Sets the scale value used to display tensors.
Sets the scale mode used to display tensors.
Sets the selected elements to be used by the tensor control.
Sets the scale factor for the shear component.
Sets the current shell layer.
Sets the state of the "Show Midside Node Results" option for the tensor control.
Sets the show prefix mode used for drawing tensor prefixes in the graphics area.
Sets the show value mode used for drawing tensor values in the graphics area.
Sets the tensor format.
Sets the tensor plot text color.
Sets the maximum threshold.
Sets the enable/disable state of the maximum threshold.
Sets the minimum threshold.
Sets the enable/disable state of the minimum threshold.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
