poITensorCtrl SetDataComponent
Sets the data component for a given component label.
poITensorCtrl_handle SetDataComponent comp_label
HyperView Tcl Modify
This command sets the data component for a given component label.
Note: Dimension must be enabled before setting.
comp_label
The data component label.
Returns 0 if successful, otherwise an error code.
