Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Restriction: Available in Abaqus, LS-DYNA, Nastran, OptiStruct, and Radioss.
Creates one hexa cluster per connector and realizes a node to node connection to the
linked shell meshes by adjusting it (shell coating). Different patterns are available.
This is driven by the number of hexas. The appearance can be influenced via the diameter
and the washer layer activation.
For LS-DYNA, the property script
prop_acm_coating.tcl is used.
ACM Realization Options
Option
Action
thickness
Select a thickness
option used for dimensioning and positioning hexas.
shell gap
Project the hexa spot to touch the shell
elements.
The position is independent from any thickness.
equival. (T1+T2)/2
Create hexa elements with RBE3 elements projecting
and connecting to the surrounding shell
elements.
This realization uses the shell thickness to
calculate the hexa offset from the shell elements.
In the case where the model is a 3T connection, the
acm (equivalenced-(T1+T2)/2) realization will join
the hexa elements.
detached (T1+T2)/2
and connecting to the surrounding shellstr
elements.
acm (detached-(T1+T2)/2) realization will not join
the hexa elements.
mid thickness
Calculate the hexa spot size (thickness) as the air
gap between the two connected parts. If there is no
gap, or even a penetration, the hexa spot size will
always be modeled with 1.0.
const thickness
Specify the hexa spot size (thickness).
maintain gaps
Calculate the hexa spot size (thickness) as the gap
distance reduced by two times the specified value
for maintain gaps.
num hexas
Create a hexa cluster
with 1, 4, 8, 12, 16 or 32 hexas, which are arranged in a
predefined pattern.
Note: Available for all ACM realization
types.
coats
Define the number of
hexa elements required along the thickness. Multiple solid coats
are supported.
orthogonal
faces
Force the creation of
perfectly orthogonally-shaped hexas.
Note: Available for any kind of ACM weld, if num hexas is
set to 1.
