rbe3 (load transfer)
Use the RBE3 Load Transfer realization to create MPCs using RBE3 elements between the nodes of shell-shell, shell-solid, or solid-solid groups by using spot connectors.
Solid-Solid
Shell-Shell (Face to Face)
Shell-Shell (Edge to Face)
Shell-Shell (Edge to Edge)
Shell-Beam
- use shortest projection for center
- The closest node becomes the center of the RBE3 element.
- use connector position for center
- The exact position of the connector becomes the center of the RBE3
element.Figure 7. Use Connector Position For Center
- use coarse mesh for center
- During the realization, based on the connector position and tolerance, the closest links are determined up to the number of required layers (num layer). All other link candidates are not taken into account for the next step.
