Convert Morph Volumes
Use the Morph Volumes: Convert tool to convert morph volumes to hexahedral elements and convert hexas to morph volumes.
Define morphing preferences.
Morph constraint entities restrict or prescribe the movement of nodes during morphing, with a variety of available methods and dimensional values. These constraints are valid across all available morphing approaches and can be individually activated or deactivated at any time, even in between morphs or applying shapes.
Use the Free tool to morph mesh by moving nodes, handles, or domains, by applying shapes, or by mapping to geometry.
Use the Proximity tool to morph mesh using a simple distance or perturbation value around selected nodes, faces, edges, or shapes.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used to manipulate a mesh by manipulating the shape of the morph volume.
Use the Morph Volumes: Convert tool to load or save morph volumes from or to a file.
Use the Morph Volumes: Enclose tool to create morph volumes with rectangular or circular shapes. Enclosed mesh and connectors are automatically registered to the enclosing volumes by default.
Use the Morph Volumes: Move tool to morph or adjust morph volumes by moving vertices/handles, edges, and faces with graphical manipulators.
Use the Morph Volumes: Split/Combine tool to split morph volumes using a single or multiple locations along an edge, combine adjacent morph volumes along shared faces, join pairs of separate morph volumes, or equivalence any number of morph volume faces using a search distance.
Use the Morph Volumes: Edges tool to adjust the interaction of the morph volumes by adding or removing handles on the edge of the volumes or changing the tangency of the volumes.
Use the Morph Volumes: Register tool to review and edit the contents of morph volumes. Only registered contents will morph when morphing morph volumes. Entities that can be registered to morph volumes are nodes and connectors.
Use the Morph Volumes: Shrink/Fit to shrink selected morph volumes to fit registered nodes more tightly or alter the morph volume faces to better fit the relevant elements.
Shapes are collections of perturbations from the initial configuration of the FE mesh before the morph.
Morph a mesh by selecting a dimension in the model and change its values.
Domain entities divide the model into different domains during morphing.
Handle entities control the shape of domains during morphing.
Symmetry entities define planes of symmetry within a model so that morphs can be applied in a symmetric fashion.
Change the biasing factors associated with each handle.
Map nodes, domains, morph volume edges, or morph volume faces in your model to a line, node list, plane, surfaces, elements, or an equation using edge domains and handles to guide the process.
Mold a mesh with a variety of virtual tools, such as creating hemispherical divots, cone-shaped projections, or molding sections with feature lines.
Undo all morphs and return to the original state of the model.
Tangency conditions can extend across multiple morph volumes, meaning that handle movements at one end of the morph volume matrix can potentially affect every morph volume.
