poIIsoValueCtrl GetDimensionEnabled
Gets the dimension state: enabled or disabled.
poIIsoValueCtrl_handle GetDimensionEnabled dim_label
HyperView Tcl Query
This command retrieves the dimension state: enabled or disabled.
- dim_label
 - The given dimension. Options include: "line", "shell", or "solid".
Returns true if enabled, false if disabled.
