poIIsoValueCtrl SetDimensionEnabled
Sets the dimension state: enabled or disabled.
poIIsoValueCtrl_handle SetDimensionEnabled dim_label state
HyperView Tcl Modify
This command sets the dimension state: enabled or disabled.
- dim_label
 - The dimension state label: "line", "shell", or "solid".
 - state
 - True if enabled, false if not.
Returns 0 if successful, otherwise an error code.
