poIIsoValueCtrl SetShowMidsideNodeResults
Sets the state of the "Show Midside Node Results" option for the iso control.
iso_handle SetShowMidsideNodeResults state
HyperView Tcl Modify
This command sets the state of the Show Midside Node Results option for the iso control.
state
Boolean value to set the "Show Midside Node Results" state to true or false.
To get the state of the "Show Midside Node Results" state in iso to false:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetIsoValueCtrlHandle iso_handle
# Set the Show Mid-side Node Results to false so that midside node results are
# not computed and shown
iso_handle SetShowMidsideNodeResults false
hwi CloseStack
Returns an error if the value state cannot be applied.
