*CE_InputSigPoints
Imprints nodes or points as significant points on connectors.
*CE_InputSigPoints <select_type>=<selection> connector_mark=<mark_id> tolerance=<value>
HyperMesh Tcl Modify Command
- <select_type>=<selection>
- There are several ways to provide the ID of the mark containing the entities to be
imprinted as significant points on connectors. Valid values are 1 and 2. Only one option
can be used at a time:
- node_mark=<mark_id>
- The ID of the mark containing the nodes to be imprinted.
- point_mark=<mark_id>
- The ID of the mark containing the points to be imprinted.
- connector_mark=<mark_id>
- The ID of the mark containing the connectors on which to add the significant points.
- tolerance=<value>
- The tolerance value defining the maximum distance between the nodes/points and the selected connectors.
Examples
*createmark points 1 1-10
*createmark connectors 2 1
*CE_InputSigPoints point_mark=1 connector_mark=2 tolerance=100Errors
# Handle error
}Version History
2022.3
