*CE_RemoveSigPoints
Removes significant points from a connector.
*CE_RemoveSigPoints ce_id
HyperMesh Tcl Modify Command
- ce_id
- The ID of the connector from which to remove the significant points.
Examples
*CE_RemoveSigPoints 10Errors
# Handle error
}Version History
2022.3
