*CE_CreateXMCFData
Adds seam weld connector and link data to an xml file in xMCF format.
*CE_CreateXMCFData entity_type mark_id
HyperMesh Tcl Modify Command
- entity_type
- The input entity type. Valid values is connectors.
- mark_id
- The ID of the mark containing the seam weld connectors on which data for xMCF will be extracted. Valid values are 1 and 2.
Examples
*createmark connectors 1 101 102 103
*CE_CreateXMCFData connectors 1Errors
# Handle error
}Version History
2022.3
