surfaces
Unless otherwise specified, data names are accessible in level 3 only.
- area
- The area of the surface.
- attributesmax
- The number of attributes owned by this entity.
- collector
- Pointer to the collector that owns the element.
- definedentity
- True if the entity is defined, false otherwise.
- geometrytype
- The type of geometry (CAD or FEGeometry). Valid for hm_getvalue query only.
- geomid
- The internal ID in the geometry database.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- moduleid
- The module ID of the entity.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- topologytype
- The topology type of the surface (free, bounding, partition, or fin).
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022.3 - Added new data names area, geometrytype, and topologytype.
