solids
Unless otherwise specified, data names are accessible in level 3 only.
- attributesmax
 - The number of attributes owned by this entity.
 - collector
 - Pointer to the collector that owns the element.
 - definedentity
 - True if the entity is defined, false otherwise.
 - geometrytype
 - The type of geometry (CAD or FEGeometry). Valid for hm_getvalue query only.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - mappability
 - The mappable state of the solid.
 - moduleid
 - The module ID of the entity.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - topologytype
 - The topology type of the solid (1dmappable, 3dmappable, unmappable, or ignoredmappable).
 - volume
 - The volume of the solid.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022.3 - Added new data names geometrytype, mappability, topologytype, and volume.
