*elementtype
Sets the global element type variable.
*elementtype config type
HyperMesh Tcl Modify Command
- config
- The configuration whose global type is set with this command. This input can be specified as config number or config string label.
- type
- The type whose global type is set with this command. This input can be specified as type number or type string label.
*elementtype 103 3 *elementtype tria3 CTRIARVersion History
2022.3 - Added support for string labels as input arguments.
