charts
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
averaging
The averaging mode.
Type: string
chartreview
The chart preview.
Type: Boolean
chartvisibility
The chart visibility.
Type: Boolean
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
corner
The flag to request corner data.
Type: Boolean
datacomponent
The datacomponent corresponding to the datatype specified.
Type: string
datatype
The result datatype used for plotting.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
enableYaxis
The flag enabling the y axis for visualization.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
layer
The layer corresponding to the datatype specified.
Type: string
Linecolor
The color of the line.
Type: integer
linestyle
The style of the line.
Linethickness
The thickness of the line.
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
References
The different coordinate systems present as references.
Type: Boolean
shadealpha
The darkness of the shaded area.
Type: double
shadearea
The flag to enable the shading of the area prescribed by the curve.
Type: Boolean
shadecolor
The color of the shading.
Type: integer
shadestyle
The style of the shading.
Type: string
Size
The size of the table.
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
source
The chart entity source.
Symbolcolor
The color of the symbols.
Type: integer
Symbolfrequency
The frequency of the symbols.
Symbolscale
The size of the symbols.
Symbolstyle
The style of the symbols.
tableid
The ID of the table entity.
Type: entity
xaxis
Flag to enable the table column selection as x axis data source.
Type: Boolean
yaxis
Flag to enable the table column selection as y axis data source.
Type: Boolean
Version History
2022.3
