points
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
coordinates
The coordinates of the point.
Type: triple double
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
geometrytype
The type of geometry (CAD or FEGeometry). Valid for hm_getvalue query only.
Type: string
geomid
The internal ID in the geometry database.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
topologytype
The topology type of the point (none, vertex, or fixed).
Type: string
x
The x coordinate of the point.
Type: double
y
The y coordinate of the point.
Type: double
z
The z coordinate of the point.
Type: double
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022.1 - Added new data name coordinates.
2022.3 - Added new data names geometrytype and topologytype.
