lines
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
endcoords
The coordinates of the line end point.
Type: triple double
endtangentangle
The angle between the tangent vector and the z-axis at the line end point.
Type: double
endtangentvector
The components of the tangent vector at the line end point.
Type: triple double
geometrytype
The type of geometry (CAD or FEGeometry). Valid for hm_getvalue query only.
Type: string
geomid
The internal ID in the geometry database.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
length
The length of the line.
Type: double
moduleid
The module ID of the entity.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
length
Type: double
startcoords
The coordinates of the line start point.
Type: triple double
starttangentangle
The angle between the tangent vector and the z-axis at the line start point.
Type: double
starttangentvector
The components of the tangent vector at the line start point.
Type: triple double
topologytype
The topology type of the line (none, free, shared, nonmanifold, or suppressed).
Type: string
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022.3 - Added new data names endcoords, endtangentangle, endtangentvector, geometrytype, length, startcoords, starttangentangle, starttangentvector, and topologytype.
