*elementqualitysplitelem
Splits a quad element into two trias.
*elementqualitysplitelem elem_id=<value> swap=<value>
HyperMesh Tcl Modify Command
This command splits a quad element into two trias.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_id=<value>
- The ID of the element to split.
- swap=<value>
- Element swap check.
*createmark elems 2 all
*elementqualitysetup_new 2
*elementqualitysplitelem elem_id=20 swap=1
*elementqualityshutdown 0Errors
# Handle error
}Version History
13.0
2022.3 - Updated the syntax to support name-value argument pairs and added new option swap.
