*findmark
Finds and displays entities or finds and displays adjacent entities.
*findmark entity_type mark_id function adjacent adjacent_entity_type numbers output_mark_id ?recursive?
HyperMesh Tcl Modify Command
This command finds and displays entities or finds and displays adjacent entities.
- entity_type
- The entity types to find or to use for finding entities adjacent to.
- mark_id
- The mark ID containing the entities. Valid values are 1 and 2.
- function
- A flag that indicates the find function to perform. Bit values are used and the value
is calculated as (1*Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3 + 16*Bit4 + 32*Bit5 + 64*Bit6
+ 128*Bit7).
- Bit0
- Find mode.
- Bit1
- Find connectors and realized FE.
- Bit2
- Find tied contact entities.
- Bit3
- Unused
- Bit4
- Find free surface edges when finding lines.
- Bit5
- Find shared surface edges when finding lines.
- Bit6
- Find non-manifold surface edges when finding lines.
- Bit7
- Find suppressed surface edges when finding lines.
- Bit8
- Exclude group elements when finding elements.
- Bit9
- Consider Constraints when finding Elements/Components attached to other Elements/Components.
- adjacent
- 0 - Add both entities on mark_id and those found to output_mark_id.
- adjacent_entity_type
- If function is 0, this should be the same as entity_type. Otherwise, it is the type of entity to find. The found entities will also be displayed. If set to undefined, all supported adjacent entities will be found.
- numbers
- 0 - Do not turn on numbers for the found entities.
- output_mark_id
- The mark ID to put the found entities on.
- recursive
- The recursive flag will work only if both input and output entity types are the same.
*createmark elements 1 12
*findmark elements 1 1 1 elements 0 2*createmark connectors 1 all
*findmark connectors 1 0 1 connectors 0 2*createmark lines 1 all
*findmark lines 1 240 1 lines 0 2Errors
# Handle error
}Version History
2020 - Added new function Bit2 value.
2022.3 - Added new function Bit9 value and new option recursive.
