*splitelementbyelemselect
Splits shell element patches using patterns based on the patch shared edges.
*splitelementbyelemselect elem_mark=<mark_id> ?option1=<value1>? ?option2=<value2>? ... ?optionN=<valueN>?
HyperMesh Tcl Modify Command
- elem_mark=<mark_id>
- The ID of the mark containing elements to split. Valid values are 1 and 2.
- consider1ds=<value>
- Check for 1D elements during the split operation.
- dividequadsoptions =<value>
- The orientation of the diagonals of the selected elements after split.
- midpointoptions =<value>
- The element split pattern at the midpoint.
- reverseorientation =<value>
- Check for switching to the other diagonal within each selected element.
- splitallsidesoptions =<value>
- The mode in which trias are split if “SplitAllSides” is the split mode. This option is effective only if splitoptions is set to SplitAllSides and splitnumberedges is set to 1.
- splitnumberedges =<value>
- The number of splits in each edge of the selected elements. Default value is 1.
- splitoptions =<value>
- The split mode.
- useinferredgeometry =<value>
- Checks for using inferred geometry from the nodes when the underlying geometry is not specified.
- useadjacentlayer =<value>
- Checks for using a layer of adjacent elements as transition elements for split operations.
Examples
To split elements ID 10 and 11:
*createmark elements 1 10 11
*splitelementbyelemselect elem_mark=1 splitoptions=SplitAllSides splitallsidesoptions=Quads consider1ds=1 splitnumberedges=5 useinferredgeometry=1 useadjacentlayer=0
# Handle error
}Version History
2021
2022.3 - Updated the syntax to support name-value argument pairs and added new option consider1ds.
2023 - Added new options dividequadsoptions, midpointoptions, reverseorientation, splitallsidesoptions, splitnumberedges, splitoptions, useinferredgeometry and useadjacentlayer.
