poIRenderOptions GetMeshDetails
Gets the current value of the mesh detail slider.
poIRenderOptions_handle GetMeshDetails
HyperView Tcl Query
This command returns the current value of the mesh detail slider (1 to 100). A lower value means that mesh lines are less likely to be displayed for fine meshes, and vice versa. A value of 100 means mesh lines are always shown, regardless of how fine the meshes are.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options GetMeshDetails
hwi CloseStack
None.
