poIRenderOptions SetViewCubeGeometry
Sets the view cube geometry state.
poIRenderOptions_handle SetViewCubeGeometry geometry
HyperView Tcl Modify
This command sets the view cube geometry state.
geometry
Set to "chamfered cube" or "simple cube". Alternatively, “chamfered” or “simple” may also be used.
Only valid when using HyperView. Returns 0 if successful, otherwise an error code.
