poIRenderOptions SetViewCubePosition
Sets the view cube position.
poIRenderOptions_handle SetViewCubePosition position
HyperView Tcl Modify
This command sets the view cube position.
position
Set to "lower left", "lower right", "upper left" or "upper right". Alternatively, "lowleft", "lowright", "upleft" or "upright" may also be used.
Only valid when using HyperView. Returns 0 if successful, otherwise an error code.
