poIRenderOptions SetViewCubeRotatorIncrement
Sets the view cube rotator increment angle.
poIRenderOptions_handle SetViewCubeRotatorIncrement increment
HyperView Tcl Modify
This command sets the view cube rotator increment angle.
- reflectors
- Rotator angle in degrees.
Only valid when using HyperView. Returns 0 if successful, otherwise an error code.
