poIResultMathCtrl GetOperatorDefaultArgumentSyntax
Gets the syntax of the operator used in the expression builder when the default arguments are ignored.
rmath_handle GetOperatorDefaultArgumentSyntax lib oper
HyperView Tcl Query
This command retrieves the syntax of a result math operator when the default arguments are ignored.
- lib
- The name of the result math library.
- oper
- The name of the result math operator.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
rmath_handle GetOperatorDefaultArgumentSyntax math log
hwi CloseStack
None.
