poIResultMathCtrl SetLabel
Sets the label of the result math expression.
rmathexp_handle SetLabel label
HyperView Tcl Modify
This command sets the label of the result math expression.
- label
- The label for the expression. The label cannot be the name of an existing data type. In addition, the label cannot contain any of the following characters: '[',']','{','}','\'','\','<','>','&', ':'.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set eid [rmath_handle AddExpression]
rmath_handle GetExpressionHandle expr_handle $eid
exp_handle SetLabel "myexpression"
hwi CloseStack
Returns a non-zero value if there is an error.
