poIResultMathCtrl GetTableComponentList
Gets the components associated with a table.
rmath_handle GetTableComponentList res_name table_name
HyperView Tcl Query
This command returns the components associated with a table. For example, a vector table will have x, y, z and mag as the components.
res_name
The name of the resource where the table is available.
table_name
The name of the table whose components are needed.
To get the component list of the specified table:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set tabcomp_list [rmath_handle GetTableComponentList model Stress]
hwi CloseStack
None.
